C2 M20 downshifting problem - NCRS Discussion Boards
  • Grant M.
    • August 31, 1995
    • 448
    Can anyone suggest the speed range at which downshifting from second to first should be able to be done (without double-clutching) on a (1965) M20? the transmission has just been professionally rebuilt and on initial drives, downshifts around 15 mph or so were no problem, and then, after re-installing the console, it now grinds and won't go into gear when trying to downshift to first, except at very low speeds, ie: 1-2 mph. Shifting into first from a start is no issue; the transmission is smooth and noise and vibration-free.
    Thanks for any advice,
    Grant
  • Mel S.
    • August 31, 1992
    • 264
    Re: C2 M20 downshifting problem
    sounds like you have a stuck or broken syncro ring.
    Mel
    • Grant M.
      • August 31, 1995
      • 448
      That was kind of what I thought. Car's going back to the transmission shop in the morning (3 1/2 hrs on a trailer).
      Grant
        • 43273
        Grant
        Grant-------
        The only brass synchro (blocking) rings that I have ever found that work absolutely correctly are the ORIGINAL GM rings. Even the GM replacement rings (6 digit part numbers) are not as good as the originals. I highly doubt that your transmission shop will have any of even the GM replacements, let alone the originals.
        • James W.
          • December 1, 1990
          • 2671
          Joe,
          What is the correct GM part number that would be a good replacement if they could be located?
          James
          Grant-------
            • 43273
            Originally posted by James West (18379)
            Joe,
            James
            James-------
            Well, I'm in Italy right now so I do not have my references available and I just don't have these particular part numbers committed to memory.
