1963 Wiper Motor - NCRS Discussion Boards
1963 Wiper Motor
  • Gerald C.
    • June 30, 1987
    • 1310
    1963 Wiper Motor
    My wiper motor doesn't run nor click when I put the switch on either Hi or Low speed. However, when I push the washer button in, there is clicking inside the motor. So it appears that the switch is working.....maybe.
    Any thoughts or ideas for me to address? I would try to avoid taking the motor out as you all know, it's a PITA.
  • Gary B.
    • February 1, 1997
    • 7065
    Re: 1963 Wiper Motor
    Gerald,
    If you need advice about wiper motors, I recommend calling Steve Hackel. He knows as much as anyone about them.
    SteveHackel
    Restoration Service
    15000 South Knox Ave
    Midlothian, IL 60445
    708-687-4183
    Gary
      • 6955
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 926
        Jerry, Check the ground to the wiper motor. The washer doesn't used the chassis ground. It is only connected to the switch. Obviously you have a good ground to the switch and power to the brown wires connected to the motor. If the black wire has no ground your motor won't work.
        That ground originates at the Starter. Very often people connect it to the positive side of the Starter because it has a large diameter connector. It should be grounded to one of the 2 starter bolts. Check there if the black wire is connected at your wiper motor.
