Heater Hose Mounting - NCRS Discussion Boards
+ More Options
Posts
  • Paul A.
    • April 21, 2021
    • 227
    Where on the inner fender well does the heater hose bracket mount? 66 BB. As per assembly manual there are 3 straps. I believe center one gets screwed to the well? Also what type of screw?
  • Leif A.
    • August 31, 1997
    • 3644
    Re: Heater Hose Mounting
    Paul,
    Measurements for the placement of the heater hose clamp is defined in the '66 AIM, UPC L72, B4. I have attached a copy. The picture of the clamp that you show that attaches to the inner fender well is incorrect for a '66 BB w/o A/C. The correct part is available from Paragon.
    https://www.paragoncorvette.com/prod...nder-clamp-kit
    Leif
    • Paul A.
      • April 21, 2021
      • 227
      Leif, I have a single screw hole clamp which would be incorrect. Good link. Thanks for that clarification. Paul.
