Please share pictures of proper/correct rear caliper brake line routing (1967 BB) - NCRS Discussion Boards
  • Brian E.
    • May 28, 2018
    • 288
    Would someone please be willing to share some pictures that clearly illustrate where and how these rear caliper brake lines are supposed to exist for a 1967 (with sway bar)? Perhaps pictures from untouched or bowtie cars?
    Are they supposed to ride in the tight space above and outboard of the trailing arm (where mine are now)? Are they supposed to ride more out in the open (inboard of where mine are now)? I purchased new brake lines (they haven't shipped yet) but at this point I think I just need to see real pictures of where these brake lines are supposed to be.
    Thanks in advance.
    Below are some pix of my car's (soon to be replaced) brake lines showing at least 2 points of contact (red arrows) on the drivers side. These are the same brake lines that were on my car when it was delivered to me after the purchase, so I simply presumed they were okay. Now that I know of the contact points, I am uncomfortable with them, I feel they are unsafe (over time), and I want to addressed this issue before bleeding / flushing the brake lines.
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: Please share pictures of proper/correct rear caliper brake line routing (1967 BB)
    These are from a 67 BB with rear sway bar. Lines had some "spiral armor" in the close areas. Hope these help.....
    Your lines probably need a little "adjustment". The lines do not move independently of the surrounding area, so "close" isn't a problem once installed.
    • Brian E.
      • May 28, 2018
      • 288
      Thank you Stephen. My new brake lines (from paragon have shipped today). Can't wait to get them, install them, and get closer to having the rear suspension done. Thanks again.
