Ignition Coil Troubleshooting - NCRS Discussion Boards
+ More Options
Posts
  • Christopher R.
    • March 31, 1975
    • 1599
    My '62 wouldn't re-start after a long hot drive. The car was towed home. After a few days rest, I tried to start it. No luck. Not even a cough. Changed the coil, and it started instantly. Sounds like a bad coil, right?
    Tested the suspect coil today. The primary resistance between the (+) and (-) terminals is 1.2 ohms. The secondary resistance between the coil tower and the (+) terminal is 10.57K ohms. Both of these numbers are within typical values.
    So, is the coil bad?
  • Dave S.
    • August 31, 1992
    • 2930
    Re: Ignition Coil Troubleshooting
    Chris,
    The only way to thoroughly test a coil is on a running car. If the coil is fully heated up and it does not work then it is no good. Not repairable either.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11356
      Since it still failed later after cool down, and after you swapped it out, now good, maybe there was a bad connection somewhere. Maybe in the process of changing it, you unknowingly fixed a connection issue.
      I'd carefully check the Green wire from Ballast to coil+, as well as the Black coil- to distributor.
      Another possible issue is the Black wire inside the distributor connecting the points breaker plate to ground.
      I'd do a retest. Start it will the present config with new coil. Shut down. Install the suspect coil and try to restart. I suspect it will since it meets spec. Let it warm up to normal temp.
      As Dave said, coils typically fail when hot, but since it still failed cold , something else may be a issue.
      Maybe even Ign power from Ign switch. A test light or meter can help find that if no-start. Meter the coil+ to verify 12v first.
      Rich
