67 Door panel vapor barrier - NCRS Discussion Boards
  • John D.
    • June 30, 1991
    • 875
    Do 67's have the paper type door panel vapor barrier or is it the plastic one as the parts suppliers suggest ?. The car has a dried out brown paper one now. Early 67 car.
  • Tom E.
    • June 1, 2019
    • 448
    Re: 67 Door panel vapor barrier
    It is my understanding the early cars had paper and the later cars received the polyethylene plastic. I have a September build 67 and it was paper so my guess would be a bit later than that.
    • Leif A.
      • August 31, 1997
      • 3643
      The '67 AIM call out paper inner panel liners. The plastic ones available will certainly work and they're not judged. Or, you can get some heavy brown paper from most big box hardware store or local nursery and make your own liners...just a thought.
      Leif
      • Owen L.
        • September 30, 1991
        • 882
        I'm prettty sure my unrestored May '67 (owned since 12/79) has the plastic barrier.
        • Lawrence S.
          • April 1, 1993
          • 803
          Before I restored my November 66 built roadster it still had the original passenger door panel installed. When I removed it the plastic liner was installed.
          My January 67 BB Coupe with original interior has the plastic liners behind the door panels.
          Hope this helps.
          • Michael M.
            • February 1, 1993
            • 604
            What I have seen on mostly 1966 cars is a combination of black plastic and brown paper as a one-piece vapor barrier. Black plastic on one side and brown paper on the other side.
            • Gary B.
              • February 1, 1997
              • 7046
              • Bill M.
                • 1328
                My may built coupe has a clear plastic barrier
                • Enzo C.
                  • January 12, 2012
                  • 534
                  My all original February built 67 has the plastic also
                  Enzo Colosimo
                  Ncrs Ontario Chapter Chairman 🇨🇦
                  ENZ-Z06/67
