1965 Tail Light Wiring Harness Support Clip Locations - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2668
    Do the rear wiring harness support clips attach to the left and right side innner most light, top speed nut? Also the wiring clip that attaches above the license plate light. I don't have my '65 AIM with me to reference.
    James
  • Leif A.
    • August 31, 1997
    • 3644
    Re: 1965 Tail Light Wiring Harness Support Clip Locations
    Your recollection appears to be correct. See item #2 (clip) from the '65 AIM.
    Leif
    • James W.
      • December 1, 1990
      • 2668
      Leif,
      Thanks, I thought I was correct, but wanted to be sure before putting the tail lights back in followed by the gas tank.
      James
      • James W.
        • December 1, 1990
        • 2668
        I've installed the passenger's side rear wiring support clip above the inboard light as described in "65 AIM.
        Is this the correct orientation?
        James
        • Leif A.
          • August 31, 1997
          • 3644
          James,
          Yes, it is.
          Leif
          • James W.
            • December 1, 1990
            • 2668
            The note in the AIM for the passenger's side wire harness clip says inboard which I have done, but the drivers side looks like it is on the top, outboard light? Also the center clip looks to be on the left side of the license plate light, but it fits better at the center. What would be correct? I only want to do this once since I'm going to put the gas tank back in tomorrow.
            James
            Originally posted by Leif Anderson (29632)
            James,
            Yes, it is.
            • Leif A.
              • August 31, 1997
              • 3644
              James,
              Place the license clip where it fits best and holds the harness out of the way...it's not going to be judged.
              Leif
              • James W.
                • December 1, 1990
                • 2668
                Done!
                James
                James,
