Radiator Hose Clamp Finish - NCRS Discussion Boards
  • Rick C.
    • March 1, 1986
    • 183
    Were the tower clamps used on 61-62 radiator hoses stainless?
    Rick
  • David B.
    • March 1, 1980
    • 690
    Re: Radiator Hose Clamp Finish
    I think I can answer your question but need a part number to be sure.
    • Rick C.
      • March 1, 1986
      • 183
      Thank you, David. Now that I'm looking at those I have, maybe they're just natural steel. Anyhow, part number for the lower hose clamps is 274765 and for the top 9411656. Thanks!
      Rick
      • David B.
        • March 1, 1980
        • 690
        9411656 Type C hose clamp, slotted hex head screw 12-24 x 1.00 corrosion resistant steel SAE 1010 2.06 open, 1.69 closed Band width .505 marked with size 66 on band.
        274765 Type C hose clamp, slotted hex head screw 12-24 x 1.00 corrosion resistant steel SAE 1010 2.31 open, 1.94 closed Band width .505 marked with size 74 on band.
        • Rick C.
          • March 1, 1986
          • 183
          David,
          Again, thank you! You often provide good specific information to this board. May I ask your source? Specifically for this thread. Thanks!
          Rick
