BR Coil vs. non-BR - NCRS Discussion Boards
BR Coil vs. non-BR
  • Floyd B.
    • November 1, 2002
    • 1051
    BR Coil vs. non-BR
    Is there any difference between Delco Remy ignition coils embossed with BR or B-R and coils that are not?
    "Drive it like you stole it"
  • Mike E.
    • February 28, 1975
    • 5141
    Re: BR Coil vs. non-BR
    All I know is that BR stands for ballast resistor. TI coils, for example, have no BR.
    • Floyd B.
      • November 1, 2002
      • 1051
      So does the BR indicate the coil has an internal ballast resistor, thus it does not need an external ballast resistor or resistor wire? My '69 390HP car currently has a 287 B-R coil with a new engine harness from M&H with the resistor wire to the coil. It seems to crank and run fine, but does my coil connection now effectively have two resistors in the path to the coil?
      Thanx
        • 15632
        Thanx
        Floyd
        My understanding is that the coils marked (or de-bossed) BR or B-R are for use with an external Ballast Resistor or resistance wire. There is no internal ballast resistor.
        That belief comes from conversations with a friend (RIP) who wound coils for Fords (can I use that term here of will the nannies make it ****?) vehicles. And yes I tried to get his equipment when he passed, but his fellow **** enthusiasts got there first.
        • Floyd B.
          • November 1, 2002
          • 1051
          Terry,
          That would make sense, since my ignition seems to work fine. It's interesting that the TIM&JG states that original 287 coils did not have the B-R but all points ignition cars used the resistor wire.
          • Dave S.
            • August 31, 1992
            • 2930
            Terry,
            If my memory serves me right I thought all 287 coils had the B - R embossment. I have one that has it but It seems that all I have seen do as well.
            • Floyd B.
              • November 1, 2002
              • 1051
              Thanx Dave,
              The one I have has "B-R" but it is far from being original to the car.
              • Jeffrey S.
                • May 31, 1988
                • 1899
                I still have the original coil that came in my 69 and it has the B-R on it.
                Jeff
                • Floyd B.
                  • November 1, 2002
                  • 1051
                  Jeff,
                  Which engine option do you have? According to the TIM&JG, "Those numbered 270 and 263 may have 12V or BR below the numbers about one-half inch down from the top. Those marked 272 and 287 have only those numbers about 1-1/2 inch from the top."
                  • Jeffrey S.
                    • May 31, 1988
                    • 1899
                    It is a small block automatic. car built in October of '68.
                    Jeff
                    • Floyd B.
                      • November 1, 2002
                      • 1051
                      TI or points?
                      • Jeffrey S.
                        • May 31, 1988
                        • 1899
                        The car has points ignition.
                        • Floyd B.
                          • November 1, 2002
                          • 1051
                          That would match the information in the TIM&JG, ""Those numbered 270 and 263 may have 12V or BR below the numbers about one-half inch down from the top." 350HP with standard ignition had 270 coils.
