wiring a 67 horn relay - NCRS Discussion Boards
  • Louie C.
    • March 1, 1980
    • 43
    hooking up the wires to my 67 horn relay. Which spade does the green wire go on and which does the 20 gauge black wire go to?
  • Leif A.
    • August 31, 1997
    • 3653
    Re: wiring a 67 horn relay
    Louie,
    Picture of my '67 with factory A/C. There are (2) plug-in connections on the bottom of the '67 horn relay; the green wire that feeds 12V to the horns goes to the lug inboard, and the other gets the black wire that goes to the horn button goes to the lug closest to the radiator support. The screw-terminal buss gets a 10-ga. red wire under one screw, and a 20-ga. orange wire (fusible link) with a molded splice to a 16-ga. black/white wire under the other screw (doesn't matter which wire is under which screw - both screws are on a common "hot" buss). There's also a black ground wire from the harness that goes under the screw that attaches the horn relay to the radiator support. The third red wire in my pictures (on the right spade) is for the factory A/C. Hope this helps.
    Leif
    • Louie C.
      • March 1, 1980
      • 43
      Thanks Leif, I appreciate the pictures and reply
      • Gary J.
        • April 1, 1980
        • 1246
        More pictures
        3F21BAE7-9246-449E-80F8-753A5C5084C6.jpgB619C640-4B3F-4454-89A8-FC53ECE3DB3E.jpgEC8268CC-7381-4F5E-BB29-44317D58E629.jpgAE30260E-417C-4727-8EF3-1A1EB04DC51E.jpg
