No Start Condition - NCRS Discussion Boards
No Start Condition
  • Christopher R.
    • March 31, 1975
    • 1599
    No Start Condition
    Trying to determine a no start condition. Pretty sure it's electrical. Battery and starter are good - cranks well. I suspect the aging coil. Maybe the distributor. Working alone. No helper to crank the engine while I hold a plug wire close to a ground. My troubleshooting was interrupted. I won't get back to this until tomorrow. One question.
    With the ignition switch in the "ON" position, shouldn't I get a spark when I hold the coil wire to ground?
    By "coil wire" I mean that wire that goes from the center of the coil to the center of the distributor.
  • Mark E.
    • April 1, 1993
    • 4530
    Re: No Start Condition
    No. Only while cranking.
    To crank the engine by yourself, jump the starter solenoid using a remote starter button or screwdriver.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Pat H.
      • December 1, 1996
      • 419
      This happened to me a few years ago when I did the tune up on my 59. I have original points (in the foil box) and a condenser D-204 in the box as well. I installed everything and it was a no start. The car ran fine before I did the tune up. By process of elimination, it was the condenser that was bad, even thought it was new in the box. I installed the old condenser and it started right away. Still running strong
      • Terry D.
        • May 31, 1987
        • 2691
        And the solution was ??
        • Pat H.
          • December 1, 1996
          • 419
          I just replace the condenser with the old one. Still running fine
          • Terry D.
            • May 31, 1987
            • 2691
            Was asking the OP
            • Leo G.
              • August 31, 1987
              • 116
              So can we look forward to what the problem was. Many of us are interested.
              Drive em safe
              Leo
              • Christopher R.
                • March 31, 1975
                • 1599
                Sorry for the delay. I didn't get to this until recently. Before I replaced any parts, I tried to start the car. No luck. Not even a cough. I replaced the coil, and it started right up.
                I suspected the coil because I had just driven 90 minutes at highway speeds on a very hot day. While the temperature gauge read 180, it was very hot under the hood.
                I'm going to carry a spare. Any recommendations?
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11323
                  Napa Part# IC12
                  • Leo G.
                    • August 31, 1987
                    • 116
                    Thanks for the response and explanation. I believe I will pack a spare when I deem it necessary.
                    Drive em safe
                    Leo
