pretty wild Idea - NCRS Discussion Boards
pretty wild Idea
  • Bruce W.
    • June 30, 1997
    • 358
    pretty wild Idea
    Hey Guys, want to run something by the experts. am having trouble finding the oil leak on my 65. looks like it is coming from the rear main seal. have replaced it twice plus the oil pan gaskets. So i am talking to an "expert" and he tells me that because I am running 456 gears that the higher RPM is causing pressure in the oil pan forcing out the oil. Sounds a little wild to me? Has anyone ever experienced anything like this?
    BW
  • William B.
    • April 30, 1975
    • 939
    Re: pretty wild Idea
    Possible higher rpms might cause this, but unlikely, unless you are keeping the rpms near the redline all the time?? 5-7000rpms. With 456 gears around town you shift alot more, start out in 2nd gear even, I switched out my 456's for 411's, still high but at least I can go 70 mph on the highway.
    • Mike M.
      • May 31, 1974
      • 8381
      get a new expert. mike
      • Dan B.
        • July 13, 2011
        • 545
        Did you replace the rear seal yourself, it's very easy to have a repetitive leak there if the proper seal is not installed per the seal makers instructions.
        RPM's have nothing to do with oil leaks.
        • Mark E.
          • April 1, 1993
          • 4528
          Clean up the outside of the engine really good (Dawn dish soap, warm water and a scrub brush work great), then add UV dye to the crankcase and look for leaks using a black light.
          It's surprising how many RMS leaks are really from the valve covers or oil sending unit.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Gary C.
            Administrator
            • October 1, 1982
            • 17648
            Bruce,
            Have you checked the PCV valve to make sure its functioning ?
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Bruce W.
              • June 30, 1997
              • 358
              no had a guy with 50 years of experience. sounded bogus to me. Mike McCagh had the best advice "get a new "expert"
              BW
              • Bruce W.
                • June 30, 1997
                • 358
                William, certainly not driving at red line
                • Philip A.
                  • February 26, 2008
                  • 329
                  Originally posted by Gary Chesnut (5895)
                  Bruce,
                  Gary
                  Had same/similar oil leak situation and this was the cause. At higher rpms, pressure would build inside engine and blow oil out past the rear intake manifold gasket.
                  • Bruce W.
                    • June 30, 1997
                    • 358
                    does a 65 327 have a PCV valve?
                    BW
