71 Lt-1 engine suffix code - NCRS Discussion Boards
  • Robert G.
    • April 13, 2017
    • 72
    Hello,
    Can you please let me know what the engine suffix code is as it would appear on underside of block , see JG example in photo.
    Thank you
    Bob
  • Ron G.
    • December 1, 1984
    • 866
    Re: 71 Lt-1 engine suffix code
    Bob, The 1971 LT-1 Engine code is: CGZ. It was written upside down on the side of the block in a yellow grease pencil. This told the line workers working at Flint exactly what internals will go into the engine block. - Ron
    "SOLID LIFTERS MATTER"
    • Ron G.
      • December 1, 1984
      • 866
      • Gary B.
        • July 31, 1979
        • 926
        The photo in the TIM&JG is oof a 1970 LT-1. It says CTK
        Gary Bosselman
          • 11689
          Originally posted by Robert Gallo (63502)
          Hello,
          Thank you
          Bob
          The engine suffix code written on any block (i.e. any horsepower or configuration) should be the same one that's on the stamp pad as well as on the sticker on the valve cover.
          • Kenneth B.
            • August 31, 1984
            • 2091
            Think they put the engine code there so they could get the right engine in the frame without having to look at the stamp pad.
              • 11689
              I think it was done to identify the block when going down the line at Flint or Tonawanda before the stamp or the suffix sticker ever went on the block, since it's under the paint.
              Only with age can we generally see it under the paint. St Louis and now Bowling Green look at the suffix sticker.
              • Mike E.
                • February 28, 1975
                • 5141
                Here's anblock CGZ crayon (2).jpg original. Rather faint--the "G" is in the center, the "C" is hard to see other than the bottom.
                • Robert G.
                  • April 13, 2017
                  • 72
                  Thank you Mike!
                  • Robert G.
                    • April 13, 2017
                    • 72
                    Thank you Mike!
                    • James G.
                      • August 22, 2018
                      • 808
                      great photo mike!
                      James A Groome
                      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
