94-96 Convertible Top Glass - NCRS Discussion Boards
  • Ed N.
    • May 16, 2010
    • 1003
    I'm enclosing a photo of a convertible top glass. Using a C4 94-96 JM decoder, can you determine the date of this glass???
    Please let me know.
    Ed
    Ed Nieves
    NCRS #51799
  • David H.
    • June 30, 2001
    • 1544
    Re: 94-96 Convertible Top Glass
    Ed
    26 April 1996
    or: 13 February 1993
    Either make sense in your case?
    Dave
    Sequence is Top Row: Year, Middle Row: Month, Bottom Row: Day
    "Add" Dots to determine date.
    Dot Sequence is: 1 2 4 8 16
    Note: Day of Month line is offset from Year and Month lines by half a step.
    • Ed N.
      • May 16, 2010
      • 1003
      Originally posted by David Houlihan (36425)
      Ed
      26 April 1996
      Dave
      Dave, when I put the transparency up to the photo I came up with:
      20 April, 1995
      On the first line it seemed like the 1 & 4 lined up
      On the second line it seemed like the 4 lined up
      On the third line it seemed like the 16 & 4 lined up, but I could not get the dot all the way left to fall into a circle on the sheet.
      I may be doing it wrong though.
      Thoughts???
      Ed Nieves
      NCRS #51799
      • David H.
        • June 30, 2001
        • 1544
        20 April, 1995
        Thoughts???
        Ed
        Dot Sequence values are: 1 2 4 8 16
        To get a "5" you need 1 and 4 - this means you need a "gap" between those two dots.
        Your photo does not show a gap between top line dots or "1" and "2" = 3, or "2" and "4" = 6.
        That transparency is problematic to use (at least for me) - much easier to count dots.
        Dave
        • Ed N.
          • May 16, 2010
          • 1003
          Ed
          26 April 1996
          Dave
          Dave, did from my phone and reduced the size of the photo/dots into the circles and came up with 2/13/93.
          Ed Nieves
          NCRS #51799
          • Ken R.
            • August 31, 1980
            • 308
            explain the dot for dating please?
            • David H.
              • June 30, 2001
              • 1544
              Ken
              AP Tech, C5 and some C4 glass used "Dots" aligned in a matrix to record production date.
              Top row of dots indicated YEAR
              Second row of dots indicates MONTH
              Third (bottom) row of dots indicates DAY of Month
              Some glass, like the convertible rear window above, has all three rows: Year, Month, Day.
              Front/side windows may only have TWO ROWS, indicating Year and Month.
              Complete dot sequence values are: 1 2 4 8 16 - Maximum count if all dots are visible is 31 (1+2+4+8+16), so Day of Month is covered.
              Year and Month (max 12) are covered by: 1 2 4 8 - "4" and "8" covering December
              Note that max number of dots for month and year identification is four - (Day of month row has five positions)
              Day of month row is offset forward half a step from year and month rows.
              A gap between dots means don't count that number.
              Difficulty comes with where do you start counting. An odd numbered year will have a "1" dot, an even numbered year won't.
              So is the first dot you see a "1", or a "2", or a "4"? Often dots on other rows give you an indication of where you should start counting.
              Once you use dot counts a few times it becomes much easier. And MUCH easier than the alphabet soup that LOF date codes are.
              Dave
              Trust you both are Covid free.
              • Ed N.
                • May 16, 2010
                • 1003
                Ken
                Dave
                Dam, now I'm really confused (lol).
                Ed Nieves
                NCRS #51799
                • Pat F.
                  • April 1, 1981
                  • 856
                  Ed, it is all under control per our conversation. The answer is April 26th, 1996.
                  PAT, Central New Jersey and Florida Chapters
                  • Ken R.
                    • August 31, 1980
                    • 308
                    I need to go back to high school math for this! But thanks for the lesson. We both are ok; Vicki had a bad lower back in Mobile, so stayed in the hotel room, and I just stayed away from crowds.
                    • Ken R.
                      • August 31, 1980
                      • 308
                      So here is my 2021 front windshield: are the dots shown representative of the date?
                      • David H.
                        • June 30, 2001
                        • 1544
                        [ATTACH=CONFIG]112498[/ATTACH]
                        Ken
                        Of course not!!!
                        C5 / C6 use different date coding methods. Pete Bergman is putting together our new C6 TIMJG and these glass codes are an on going issue.
                        Pete has examined numerous C6 checking build date vs dot codes trying to find a decode that makes sense.
                        Overall general scheme seems to be "******YY******" Where YY is year and dots "*" before or after YY indicate month.
                        No scheme seems to work all the time vs car's build date.
                        I would interpret **21 as May 2021 - could as easily be Feb 2021.
                        If you've got a scheme let Pete know!
                        Dave
                        • Ken R.
                          • August 31, 1980
                          • 308
                          I figured it was 3/28/2021. But who really knows. Will see what my 07 and 09 tops were. Here are the 2003 side window and front w/s showing the dots. Interesting.
                          O3 made August of 2002.
                          • David H.
                            • June 30, 2001
                            • 1544
                            Ken
                            Your two Row and three row C5 date codes.
                            Dave
