1964 coupe with added VINTAGE AIR - NCRS Discussion Boards
  • Jack J.
    • July 31, 2000
    • 640
    Where would the hood release handle (longer wire/cable) be located on a factory equipped AC car?
  • Don H.
    • December 1, 1981
    • 1496
    Re: 1964 coupe with added VINTAGE AIR
    Factory AC cars have a longer hood release bracket so it hangs lower. That is so it will have room for the left AC outlet. It might also be moved inboard some but I am not sure of that.
    • Harry S.
      • July 31, 2002
      • 5344
      Yes, it is moved.
      • Bob K.
        • March 3, 2013
        • 145
        Picture from my 66 with Vintage Air, hood release and headlight switch did not moveIMG_8745.jpg
        • Gary C.
          Administrator
          • October 1, 1982
          • 17940
          Jack,
          My '64 with Vintage Air installed in 1996.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Leif A.
            • August 31, 1997
            • 3653
            OP was asking a question regarding FACTORY A/C...not aftermarket A/C.
            Leif
            • Jack J.
              • July 31, 2000
              • 640
              Can I assume that both AC equipped cars and those without AC, that the CABLE LENGTH is the same for either bracket?
              • James W.
                • December 1, 1990
                • 2673
                Do you need one? I think I have a spare original one that needs paint.
                James
                • Jack J.
                  • July 31, 2000
                  • 640
                  jackjagello@att.net
                  • James W.
                    • December 1, 1990
                    • 2673
                    Jack,
                    Sent you an Email.
                    James
                    • Jack J.
                      • July 31, 2000
                      • 640
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17940
                        Jack,
                        Simply moved the hood release over to the right of the A/C vent. The vent cable pull was to the right of the cable pull and slightly angled.
                        Gary
                        NCRS Texas Chapter
