The JG shows and discusses the small block CJ code stamped on the fan clutch for the Eaton brand, but not the Schwitzer brand. Am I just reading it wrong, or should there be a CJ for small blocks on the Schwitzer too? Thanks.
CJ code on Schwitzer fan clutch
Re: CJ code on Schwitzer fan clutch
Go to the Sticky file section of the Tech Forum - it is above the member threads. Then find the thread called Database of Restoration Documents. Click on it and then scroll down to Clutch Fans - there are 2 great articles in PDF files - lots of pics - everything you ever wanted to know about clutch fan ID is in those 2 documents. https://www.forums.ncrs.org/showthre...tion-DocumentsEd- Top
