Distributor Rotor - NCRS Discussion Boards
Distributor Rotor
  • Jeff S.
    • July 31, 1984
    • 384
    Distributor Rotor
    Can anyone verify from recent purchase/experience that currently available NAPA/ECHLIN RR 1670 is dimensionally a "long tip - short gap" rotor? There are posts in the archive section that so indicate, but they are predominantly from ancient times. Thanks.
  • John D.
    • December 1, 1979
    • 5507
    Re: Distributor Rotor
    Jeff ,NAPA has not had the long tip rotor in ages. John
    • Hank D.
      • January 1, 1999
      • 137
      Try this.....https://www.corvettecentral.com/c3-6...%2btip%2brotor
      • Mike T.
        • January 1, 1992
        • 568
        Jeff - I have a new NAPA 1670 rotor, how do you measure one when looking for that extended tip dimension?
        Mike T. - Prescott AZ.
        • Owen L.
          • September 30, 1991
          • 882
          Mike, can you measure your cap from arrow to arrow?
          For my 4000+ misfire, someone suggested I have a short-arm cap but they didn't respond with any further info on how to tell.
          Maybe a measure how far the tip is over or under a vertical line with the lower part of the cap.
          • Mike T.
            • January 1, 1992
            • 568
            It appears I'm still having issues posting pics. One time the orientation is correct, next time, the pic is turned 90-degrees. Started a 'ticket' and John W corrected it for me but for the life of me, still can't figure out how to simply rotate the pic.
            In any case, notice the one pic that shows the square sitting flat on the workbench? Notice the taper present in the rotor skirt? Anyway, when I have the square making contact to the lower portion of that skirt, the gap appears to be an exact 1/4-inch.
            • Owen L.
              • 882
              (rotated on my Mac)
              That's perfect, thank you. Now to find out if this is "long" or not.
              • Leif A.
                • August 31, 1997
                • 3644
                Jeff,
                Zip has the correct extended tip rotor in stock.
                1957-1974 Corvette 1x4 Distributor Rotor at Zip, the source for internal & tach drive components to rebuild your Corvette's distributor. (GM Part 1852722)
                "New reproduction "black" distributor rotor for 1957-1974 Corvettes with 1x4 distributor. Features the correct extended copper tip that closes the gap left by other replacement & current GM rotors. Eliminating the gap reduces poor start conditions, eliminates crossfires, misfires and fouled plugs due to weak spark conditions. Includes mount screws."
                Leif
                • Michael M.
                  • February 1, 1993
                  • 604
                  It's hard to beat the Delco-Remy D-409 rotor. I did find one very close that Accel makes or made. Both rotors have the long tip.
                  • Owen L.
                    • 882
                    Can you do a measurement like Mike did above to see how far extended it is? (edit: Maybe that's a silly question as there is an ebay seller saying it's .0028" longer, which is pretty hard to measure this way.)
                    • Michael M.
                      • February 1, 1993
                      • 604
                      Owen,
                      My measurement says 7/8" in length on both rotors.
                      • Owen L.
                        • 882
                        Owen,
                        Is there any way to do a setup like Mike T shows here? I realized the length isn't as important as the projection from the cap's plastic body. He shows 1/4" gap.
