Re: Retorqued Intake but still seeping oil between intake/heads
Perhaps I spoke too soon. I did a good job of taping a paper towel "buffer" at the top of valve cover where it's leaking at what I thought was the source for the oil down between the intake and head. The oil is back but the area between the paper towel and the pooled oil down at the intake is clean, i.e. the area of the head between the valve cover and intake, which brings me back to believing the source is between the intake and head. Another thing I notice is that I see the pooled oil, it's very small pool maybe 1/8" wide at most, when I first check after driving the car but after about 15 minutes the pool is gone and all that's left is a bit of staining on the intake. It's as if it's being sucked back in. I don't what else would explain it.
So I checked the torque on the two center intake bolts, they're the closest to the area, and they took some torque to get to 30 ft lbs. I don't get it, is it normal to still be having to re-torque these intake bolts after at best another hour or 2 of operating time? The bolts are new, and threads clean and I used thread sealer. I did check it while it was still hot, could that explain them being < 30 ft lbs?
