Air conditioner - NCRS Discussion Boards
Air conditioner
  • Joseph R.
    • June 19, 2011
    • 63
    Air conditioner
    I need an expert to look at my air conditioning, I had it restored by conditioned air in Tampa but I cannot get cold air. Everything else works and I have a chapter top flight. If anyone has any recommendations to look at it ( within pa and Ohio ) please advise and thanks
  • John F.
    • March 23, 2008
    • 2413
    Re: Air conditioner
    Take it back to the shop.
    • Greg H.
      • 105
      Re: Air conditioner
      Typical for the hot water getting into the heater core because the shut off in not working. They share the same chamber in the heater box.
      • Greg H.
        • 105
        Re: Air conditioner
        n the heater box.
        IMG_0053.jpgEvap - this is on the firewall and the cold coil is inside, the fan is blowing on the cold coil.IMG_0793.jpgthis is on the inside and your cold air is passing through the hot heater coil if the valve is open.
        • Joseph R.
          • June 19, 2011
          • 63
          • Greg H.
            • 105
            Re: Air conditioner
            Your heater hoses are a supply and return and if the shutoff is working only one hose will be hot when the temp is at 160. That's the extent of my experience.
            Good Luck.
            • Joseph R.
              • June 19, 2011
              • 63
              Re: Air conditioner
              Gold suggestion. Will check it out
