1957 key knock out code, 4 digit 1/16 inch font - NCRS Discussion Boards
  • John G.
    Infrequent User
    • January 10, 2009
    • 25
    I am finishing a 1957, early March Corvette. I have Briggs Stratton Octagon head key. The knock out is not stamped. My locksmith said the cut on the key from shoulder to tip is 123523. I am looking for information referencing the GM 4 digit knock out code to that cut. Have any of you come across such a cross reference. Thank you in advance for your help. John Goedeken
  • Gary B.
    • February 1, 1997
    • 7087
    • John G.
      Infrequent User
      • January 10, 2009
      • 25
      Re: 1957 key knock out code, 4 digit 1/16 inch font
      100_5876.jpg Attached a picture of keys. Will add another post with more pictures. thank you. John
      • John G.
        Infrequent User
        • January 10, 2009
        • 25
        100_5899.jpgAnother photo of the 57 key for knock out code identification. Thank you for your assistance in determining the correct code. This key fits all locks of the car. John
        • Brian M.
          • November 1, 1994
          • 138
          Sent you a PM
          Brian McIntyre
          • Gary B.
            • February 1, 1997
            • 7087
            Originally posted by John Goedeken (49851)
            [ATTACH=CONFIG]112177[/ATTACH]Another photo of the 57 key for knock out code identification. Thank you for your assistance in determining the correct code. This key fits all locks of the car. John
            • Gary B.
              • February 1, 1997
              • 7087
              John,
              PS: If you are uncomfortable removing your ignition core or seat separator lock, you could take a chance and get a key cut to code 9004 and see if it works.
              Gary
              • John G.
                Infrequent User
                • January 10, 2009
                • 25
                Thank you Brian and Gary. I will follow up. The locks are original and all working. I am sure the code is on the ignition cylinder. I had them all out during the restoration but every thing is in place and working and I've learned thru the years once you've got something working correctly leave it alone. Thanks much. If I have problems from here I will be inquiring. John
                • Jeffrey S.
                  • May 31, 1988
                  • 1902
                  If the key woks the glove box lock as it should, this one is very easy to remove and get the code from the cylinder. Much easier than the other locks.
                  Jeff
                  • John D.
                    • June 30, 1991
                    • 875
                    I have a key cutter I got at a swap meet years ago and would be happy to cut a key to code 9004 gratis and mail to you- or your neighbor down the street or mother in law...lol
                    • Gary B.
                      • February 1, 1997
                      • 7087
                      John,
                      Gosh, in that case I hope my decoding of the cuts is correct! The cuts are not a slam dunk.
                      Gary
                      • John D.
                        • June 30, 1991
                        • 875
                        gary
                        This might help decode the key too..
                        • Gary B.
                          • February 1, 1997
                          • 7087
