1985 Intake manifold bolt oil leak & Colour of rocker covers - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 376
    Helping a friend with his 85 Vette to fix an oil leak on one of his intake bolts.
    What thread sealant would you recommend?
    Also, the rocker covers are black. Is this correct?
    Gary
    • 6942
    Re: 1985 Intake manifold bolt oil leak & Colour of rocker covers
    Gary, I use a permatex pipe thread sealant for the intake bolts, you will want to clean out the threads in the head and bolt (s). If you leave behind any oil it will not seal properly. I believe the valve covers had a special coating that had a silver color. You may have to do some research to find out if anyone makes a spray can that can duplicate the coating.
    • Mark E.
      • April 1, 1993
      • 4552
      Search this forum for threads recommending paint color, type and application methods for the valve covers. I haven't done it, but powder coating is a recommended method IIRC.
      They were originally silver.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Gary C.
        • April 1, 1998
        • 376
        OK Thanks Mark & Edward.
