Coil Spring Compressor Lower Block - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
  • David H.
    • June 30, 2001
    • 1578
    Re: Coil Spring Compressor Lower Block
    Mark
    AutoZone has a loaner coil spring compressor tool that works ok.
    Dave
    Judging Chairman Mid-Way USA (Kansas) Chapter
    • Keith B.
      • September 15, 2014
      • 1604
      I just use a piece of all thread and hard washers. never a problem
      • Chuck G.
        • May 31, 1982
        • 2039
        Here's all you need.
        • Mark H.
          • July 31, 1998
          • 384
          Chuck, what is the bottom plate made out of?
          • Chuck G.
            • May 31, 1982
            • 2039
            Don't laugh. It's a piece of an old lawnmower blade.
            I had another one years ago that had a chunk of boilerplate on it. Lent it to someone, and never got it back.
            • Mark H.
              • July 31, 1998
              • 384
              Well that should be easy. Same length as the block in the diagram (3.2”)?
              • Chuck G.
                • May 31, 1982
                • 2039
                Mine is 6 3/8" long, 2 3/4" wide. I just measured it.
                  • 11698
                  Tom, who made the video, sells the block.
                  I bought one from him.
                  I added a piece of adhesive-backed foam to the A-arm side so it would not scratch them.
                  I also use Grade 8 bolts and washers to attach it to the lower A-arm.
                  • Mark H.
                    • July 31, 1998
                    • 384
                    Thanks Patrick. I tried to message him but his box was full.
                      • 11698
                      Through this site or through another?
                      He's listed on here in the Members section.
                        • October 17, 2013
                        • 69
                        Been using all thread and an old tired snap on lower section for years. Love the lawn mower blade!
                        • Mark H.
                          • July 31, 1998
                          • 384
                          Through this site or through another?<br />
                          This site.
                          • Mark H.
                            • July 31, 1998
                            • 384
                            Well, a year later and I'm finally going to tackle removing the front springs and replacing the bushings on the control arms. I have procured from McMaster-Carr the following:
                            Grade B7 Medium-Strength Steel Threaded Rod, 5/8"-11 Thread Size, 2 Feet Long
                            Extreme-Strength Steel Extra-Wide Hex Nut, Grade 2H, Black-Oxide, 5/8"-11 Thread Size, Packs of 5
                            Zinc Yellow-Chromate Plated Steel Oversized Washer, Grade 8, for 5/8" Screw Size, 0.656" ID, 1.312" OD, Packs of 10
                            For the bottom, I have a piece of 3/8" steel:
                            The plate is 8" long, I may need to cut it a bit shorter but we'll see. I have some rubber or horse stall mat material to use as a buffer.
                            The steering linkage is completely removed. I figure the process to go like this:
                            -remove sway bar (replacing all the rubber while I'm there)
                            -put the car on jackstands on the frame.
                            -remove front wheels
                            -Mine is a '64, so no brake caliper to worry about
                            -Loosen lower ball joint nut and the lower control arm cross shaft bushing bolts.
                            -two nuts on the bottom of the rod to lock in place, one washer and then the plate.
                            -grease the rod and pass it through the shock tower and use two washers and a nut on top. Grease between the washers.
                            -chain/strap on spring to ???????
                            -compress spring.
                            -separate lower ball joint from steering knuckle and remove
                            -decompress spring and swing the lower control arm out of the way
                            -remove spring
                            remove control arms
                            Sounds easy. I've been working on cars for 45 years, but this is the only thing that really scares me. I'm not sure what to chain or strap the spring to. if something lets go, I think having it tied off somehow is important. What do you folks use?
                            Thanks.
                            Mark
                            • Thomas N.
                              • July 31, 2002
                              • 408
                              Mark
                              Trying to come up with a strap or chain will probably just get in the way. With this approach, the threaded rod in the center captivates and "cages" the spring assembly. You bought the higher strength threaded rod. The factor of safety is extremely high. Keep in mind the diameter of the threaded rod is about twice the diameter of a shock rod, and that is what keeps everything together on the road, and they experience cyclic loads, corrosion and other factors. Steel loves tension. If you want, I can send you a lower block that utilizes the shock mounts. Send me your address and I'll get it out to you. All I ask is that you return it back to me when you are done. Sorry, I didn't see this thread earlier. If you have any other questions, let me know.
                              NCRS New England Chapter Chairman 2022, 2024
                              N E Regional Chairman 2024
                              1967 Corvette Convertible Under Restoration
                              1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
