WCFB Troubleshoot - NCRS Discussion Boards
WCFB Troubleshoot
  • Dan L.
    • November 10, 2008
    • 85
    WCFB Troubleshoot
    1954 Corvette, 283, 097 solid cam, 4spd, dual point distributor no vacuum adv. Dual carburetors. No Hotrod stuff. Front carb is from a Chrysler, rear carb is a Chevrolet from a 348.
    I’ve got 1500-1800 miles on the restoration/rebuild and the car ran like a champ. I run/drive the car weekly, starts right up every time.
    I started it the other day, it ran at 1500rpm with choke and when I bumped off the choke, rpm’s increased to 2000-2500. I couldn’t get it any lower.
    I put a towel over front carb and there was no change in rpm. Put the towel over rear carb and engine rpm decreased. So, I’m assuming, it’s a problem with the rear carb. Tried carb cleaner around all gaskets and
    linkage, no change. I disassembled the carb and everything looked new, like it was 1500 miles ago, gaskets look new, floats were right on and the pump worked freely, secondaries closed properly and no binding linkage, no cracks or chips, cleaned and blew it out. I checked the PCV and it is working properly. I still had the high idle.
    What have I over looked? Can’t be that difficult. Car ran great one day and then this problem the next day.
    Thanks for your advice.
    DAN
  • Edward J.
    • September 15, 2008
    • 6960
    Re: WCFB Troubleshoot
    Dan is the choke butterfly fully open once engine is up to temp.? Also is the fast idle cam off the highest step?
    • John P.
      • January 1, 2006
      • 164
      Hello Dan, make sure the secondaries are not sticking open. I just had this happen on my 1957 after sitting.
      • Dan L.
        • November 10, 2008
        • 85
        Yes, choke works as it should. When it comes off choke, the idle goes higher.
        Yep, Secondaries are closed.
        DAN
          • May 31, 1974
          • 8409
          ?? vac leak?? mike
          • Dan L.
            • November 10, 2008
            • 85
            MIke , I checked all the usual sources, many times. Had it apart thinking a gasket slipped, but found nothing. It’s sure acting like a vacuum leak.
            DAN
            • Dan L.
              • November 10, 2008
              • 85
              Just an update. I bought a couple kits from Daytona Parts, replaced/re adjusted everything, both carbs working as they should.
              DAN
