Gas Tank Sending Unit Installation??? - NCRS Discussion Boards
+ More Options
Posts
  • James W.
    • December 1, 1990
    • 2676
    I am getting ready to reinstall my gas tank in my '65 coupe. Is there any installation clearance problems if I install the sending unit in the tank before I install the tank back in the car? The body is on the frame, all bumpers and frame brackets are removed.
    I know on a coupe that the gas tank filler neck can't be installed until the tank up in position.
    James
  • Dan B.
    • July 13, 2011
    • 545
    Re: Gas Tank Sending Unit Installation???
    With the body on the frame, the tank needs to be rotated into position. I would not risk damaging the sender pipe doing this, you are really not accomplishing anything that is worth taking that chance especially if you have an original sender IMO.
    • Michael M.
      • February 1, 1993
      • 606
      Totally agree with Dan.
      • James W.
        • December 1, 1990
        • 2676
        This what I was thinking also. I have plenty of room and the correct tool to reinstall the sending unit. Just wanted to get some other opinions.
        James
