68 ac compressor dragging at idle - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    68 vette small block ac system rebuilt charged with R12 and ran one time with rebuilt a6 compressor and blew seal. Installed new ac compressor no issues when charging had 46 degrees. Next day when hot, compressor works fine till idle and compressor tries to lock up and belt squeals. So every time I try to idle with ac on compressor drags and belt starts to slip. I put in 50 oz of R12.
  • Larry M.
    • January 1, 1992
    • 2688
    Re: 68 ac compressor dragging at idle
    Where did you buy the new A6 compressor??
    A few years back, apparently some AC rebuilt A6 compressors (sold by Chevrolet) had a problem just as you described. We solved the problem by buying a new ALMA A6 compressor and installing it. No problem/issues since.
    Larry
    • Ed P.
      • July 31, 2002
      • 270
      yes that is what i installed a ALMA compressor
      • Domenic T.
        • January 29, 2010
        • 2452
        Ed,
        I think you need to check pressure with gages. May be over charged.
        Dom
        • William F.
          • June 9, 2009
          • 1363
          Takes 3 pounds and 4 oz R12 total. You put in over 4 pounds with 50 oz.
          • Larry M.
            • January 1, 1992
            • 2688
            Bill:
            3 lbs and 4 oz = 52 oz.
            Larry
            • William F.
              • June 9, 2009
              • 1363
              Right! 16 oz/lb. Don't know why I divided by 12. Brain poot. You're not overcharged.
