3x2 Air Filter Options- foam or K&N - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    For 67-69 L71 or L68, other than running the OEM type foam filter, I can only find a K&N. No "regular" paper filter - or am I looking in the wrong place?
    WRT the foam filter, I suppose running it without oil is not recommended. I've concluded from reviewing posts on the forum that oiling it will result in excess oil finding it's it's way to at least the air cleaner base which has been my experience as well. I just had my carbs done and hate to think that the could get "oiled".
    Jack Ottofaro
  • Michael J.
    • January 27, 2009
    • 7170
    Re: 3x2 Air Filter Options- foam or K&N
    I was not able to find a paper filter element for the 3-2s on my '67 when I had it, so went with the K&N. I was told at the time that was much better than any of the foam type ones as a filter element for driving the car. Good luck.
    • Danny P.
      • June 30, 2002
      • 344
      On my L71 my foam element is part#A273C 34606325-873E-4818-B18F-D1FCAD733EC2.jpeg
      • Michael J.
        • January 27, 2009
        • 7170
        Do you use that as a daily driver air filter element?
        • Jack O.
          • July 31, 1996
          • 527
          Yes. Right now it's the only filter I have. So the car is a driver - you know, a few times a week when weather is nice - that's why I was wondering if running the dry foam air filter would be an issue. I'm thinking so but wanted to get others' insights but I'm only in "standard" conditions, no dirt roads for example.
          Jack Ottofaro
            • 15706
            Go to www.baldwinfilters.com. Type the AC number into the cross reference box to see if they have a replacement. If they do it will likely be a high quality cellulose filter.
            • Michael J.
              • January 27, 2009
              • 7170
              I have always replaced the filter elements used for judging with good quality ones as I converted to driving them. The original style ones are not good for driving. I have an oiled foam one (correct for judging) for my '65 L79, I quickly replaced with a NAPA Gold one for driving.
              • Mark F.
                • July 31, 1998
                • 1601
                Michael,
                was this the one you got for your 3x2?
                this is from K&N's website...
                E-1970 K&N REPLACEMENT AIR FILTER $89.99 USD
                thx,
                Mark
                • Michael J.
                  • January 27, 2009
                  • 7170
                  Yes, that's it. I used it for several years and it was fine. I bought mine at NAPA:
                  • Mark F.
                    • July 31, 1998
                    • 1601
                    Thanks, Michael
                    NAPA was out of stock, so I ordered right from K&N.
                    Did you apply a light coating of oil to the element? - or is that not needed on this kind of filter?
                    thx,
                    Mark
                    • Michael J.
                      • January 27, 2009
                      • 7170
                      The K&N come with an oil already applied. These are "permanent" reusable filters, made to be cleaned and re-oiled. I have one in my Shelby F-150 that I do that with every 25K miles or so. Here is the recharge kit: https://www.knfilters.com/99-5000-fi...ce-kit-aerosol
