why are my seat bolts too short on the front? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Guys,
    I'm installing the seats on my 69 and I have a new set of seat bolts (with the "E" headmark) but they're too short. The rears are fine but the fronts wont reach the mounting plate. I've run a tap through the plates but they still wont reach. When I use a longer non-correct bolt it works just fine. The seats mount directly to the floor in the front so there is nothing I can do to get them closer to the plate. Anyone else ever see this? Is there another place on the car that uses the "E" headmark bolt but is just longer that I can swap them out? I do not have the originals to compare to the new ones. Thanks for your suggestions.
    Mike
  • Gary B.
    • February 1, 1997
    • 7068
    Re: why are my seat bolts too short on the front?
    Mike,
    How long are the ones that are too short, measured from under the head to the tip?
    Gary
    • Michael L.
      • December 15, 2006
      • 1416
      I'm not at the shop right now but I would have to guess about an inch or so.
      • Gary B.
        • February 1, 1997
        • 7068
        • Leif A.
          • August 31, 1997
          • 3653
          Interesting that they don't reach. '67 - '78 seat track to floor bolts are all the same dimension...5/16-18 x 7/8" indented hex bolts w/captured washers as Gary stated.
          Leif
          • Michael L.
            • December 15, 2006
            • 1416
            Yes Leif those are the bolts I have. thanks for the tip Gary on AMK I'll look to order some of the 1 3/16" from them.
            • Michael L.
              • December 15, 2006
              • 1416
              Gary I've looked around on the AMK website but I can't find them. Do you have a link you can send me? Thanks.
              Mike
              • Gary B.
                • February 1, 1997
                • 7068
                • David M.
                  • September 30, 2004
                  • 533
                  Not 100% sure here as car is in other garage with the AIM...does the seat bracket get installed under or on the carpet? If under and your on the carpet that could explain the difficulty.
                  • Leif A.
                    • August 31, 1997
                    • 3653
                    OP states in his original post..."The seats mount directly to the floor in the front so there is nothing I can do to get them closer to the plate."
                    Leif
                    • Michael L.
                      • December 15, 2006
                      • 1416
                      Thanks Gary I ordered them. I had to order 25 of them to meet the $30 minimum but no biggee.
                      Mike
                      • John S.
                        • June 15, 2015
                        • 507
                        1973 L82 M21 4 Speed, very original and well documented driver/survivor
                        NW Chapter Member, 2016 Bend Regional Top Flight
                        73/74 TIM&JG 3rd Edition Revision Team Member
                        • Jeffrey S.
                          • May 31, 1988
                          • 1899
                          Michael,
                          Her is a photo of an original seat bolt from my Oct. '68 car. I just pulled it from the passenger side to take this. The head marking is "E" with 3 lines.
                          • Mike E.
                            • February 28, 1975
                            • 5141
                            • Michael L.
                              • December 15, 2006
                              • 1416
                              I will try and get some pics to post in the next couple of days. When I looked at the floor, there is a gap in between the top of the floor and the top of the mounting plate that is mounted under the car for the front bolts. I didn't look at the rears since the bolts there caught without problems. The distance from the floor to the top of the plate is about a 3/8-1/2 inch or so (the fiberglass floor seems pretty thick here), so with the thickness of the seat track I'm not surprised the bolt won't start. The mounting plate was not removed from the car during the resto so it hasn't changed from the factory. It is probably just barely missing, perhaps the very first thread or so on the plate is boogered up and won't let it catch, despite running a tap through it. I'll post pics in a couple of days when I get back into the shop.
                              Mike
