1969 L36 A.I.R. Hoses - NCRS Discussion Boards
  • Floyd B.
    • November 1, 2002
    • 1051
    The part number in the AIM (Sheet L36 - A5) matches the number in the TIM&JG (6th Edition, page 163) for the right hose - 3946007. However for the left hose, the numbers do not match. The AIM part number is 3591358 and the TIM&JG indicates that 3951353 is ink stamped onto the hose. Can someone explain this difference?
    Thanx
    "Drive it like you stole it"
    • 43281
    Re: 1969 L36 A.I.R. Hoses
    Thanx
    Floyd------
    In this case I think the AIM is in error. 3591358 is a member of a series of part numbers that I cannot find were ever released. On the other hand, 3951353 is consistent with a 1968 or 1969 released Chevrolet Division part number. By the way, neither 3951353 or 3946007 were ever available from GM in SERVICE. So, how did GM expect that the hose could be replaced if required? Well, there was once available bulk hose specific for AIR systems. It was GM #413480. So, you bought a 10 foot roll and cut it to length. While some small blocks required a molded hose on one side, big blocks did not require molded hose.
    • Leif A.
      • August 31, 1997
      • 3654
      According to a friend of mine who manufactures and sells many classic Corvette parts and who has original GM blueprints for many of these products, this is the information he provided regarding the OP's question...and, he has them available for sale.
      GM Blueprint says:
      1969 Corvette 427 with 390 HP or L-88
      3946007 is Left Side
      3591358 is Right Side
      1971 Corvette 454 with 425 HP LS-6 or ZR-2
      3951353 is Right Side
      3999201 is Left Side
      1968-1982 Corvette Smog Hoses Repro Of GM CAVEAT EMPTOR: quality accurate DocRebuild reproduction made in the USA. Includes period authentic markings, length codes & rubber manufacturers codes. 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982
      Leif
        • 43281
        GM Blueprint says:
        https://shop.docrebuild.com/1968-198...ReproOfGM.aspx
        Leif-------
        If the Doc says the 3591358 existed, then it existed. Period.
