C1 backing plate to front spindle bolt Torque - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 481
    Wondering if anyone has these torque specs for the front backing plate to spindle which also holds the steering arms on the lower bolts. I have searched everywhere and can't seem to find a spec. I have them at 45 right now but would like to have correct spec if possible.
    Sheldon
  • David B.
    • March 1, 1980
    • 690
    Re: C1 backing plate to front spindle bolt Torque
    If you cannot find the answer in the shop manual look in parts book under Grp.6.172 & 5.002. They are 7/16-20 hex hd. should be grade 8. The GM recommended torque for that particular size is 80 ft. lbs. unless stated different in the shop manual.
