A white '65 SB lost a point today for a missing 3rd belt water pump to crank., 250 or 300 engine. No way to adjust or install a belt without an idler. If this car came without an idler pully should he have lost a point?
3rd belt, water pump tp crank
Re: 3rd belt, water pump tp crank
Believe all engines came with the Jesus belt with no adjustment. You need the correct diameter belt65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
The base and 300 hp engines only had one belt. The rest of the SB's had 2 with an idler assembly. Only the big block had the "Jesus" belt. I came up with way more descriptive words when installing it.
All------
1965 250 and 300 hp small blocks were originally equipped with balancer pulley GM #3744043 and waterpump pulley GM #3790356. Both of these pulleys are 2 groove pulleys. One groove was, of course, used to drive the alternator. For cars without C-60 and/or N-40, the other groove had to be either unused or used for a captive belt. I don't know which.
I concur that no 250 or 300 hp was equipped with an idler pulley.In Appreciation of John Hinckley- Top
Simple answer is that while 63-65 250 and 300 hp had two groove pulleys on the crank and water pump, if no A/C or P/S, they only came equipped with a single belt. AIM shows only a single belt. Parts catalog look up yields only one belt. Pics in Corvette Restoration vol.2 confirm. The unused pulley groove does look incomplete but I'm convinced the came that way.- Top
After all these years, you would think you midyear guys would have already figured out which belts to use.
Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
I agree its NO fun at all. Bloody hands & pinched fingers. LOL65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
