radio delete panel - NCRS Discussion Boards
radio delete panel
  • Stephen B.
    • November 30, 2014
    • 76
    radio delete panel
    Good evening. I have a 72 coupe for about 8 years now which has been off the the road about 15 years. I have it running after alot of work from the age of the car. I do have 2 build sheets, one for the gas tank and one was up behind the dash. This was a radio delete car, which is kind of strange. The question I have WHY are the radio delete panels SO expensive?????. I understand this was an L88 issue. The car did have a radio in it which have 71 knobs, so I presume the original customer had a radio dealer installed.
  • Sal C.
    • December 1, 1984
    • 430
    Re: radio delete panel
    A) Corvettes not equipped with radios from he plant are not plentiful to begin with.
    B) Those cars usually were ordered that way for 2 reasons. Car was to be used for racing. Or original owner planned to install their own radio'
    C) Those that were raced most likely retain their original panels.
    D} Those cars with radios that were added likely had their panels tossed in the trash by a dealer or on owner.
    Reproduction delete plates are easily available and a lot less expensive than an original.
    • James G.
      • August 22, 2018
      • 800
      The original one in our other LT1 is not perfect so I was looking for a NOS one, after seeing the going prices I decided the original is close enough to PERFECT for me!
      B)/(C) - the cars which were raced were typically the hi performance models, some not available with a radio - L88 ZL1 ZR1 ZR2 - some of the most valuable Corvettes ever built - thus the prices reflect the limited availability and the fact that very valuable cars are the ones which typically missing them.
      James A Groome
      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
      • Patrick B.
        • August 31, 1985
        • 2002
        How much do people ask for a NOS radio delete plate?
        • James G.
          • August 22, 2018
          • 800
          I don't believe I have seen one under $900 in the last few years and IIRC $1200-$1500 is typical THESE are pre inflation... any of these numbers may seem like a bargain in 3 years.
          James A Groome
