69 427 LH Valve Cover J clip - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    Hi everyone,
    My LH valve cover has the spark plug wire clip on the lower side between #'s 3 and 5 plugs. It's described in the TJM but the TJM does not indicate which wire it's used to retain. Seems like it would have to be #5 but I'm not sure. Anyone know and/or have a picture of how the wire should be routed? The way I have my wires done now #5 is not long enough but it's possible I have it mixed up as I thought that clip was for the temperature sending unit wire before referring to the TJM.
    Tanks,
    Jack
    Jack Ottofaro
  • Floyd B.
    • November 1, 2002
    • 1051
    Re: 69 427 LH Valve Cover J clip
    UPC-L36 Sheet A6 of the AIM contains the spark plug wiring diagram. On the driver's side, the wires for cylinders 1 & 3 are secured by the retainer on the top surface of the valve cover. To my knowledge, this is the only clip/retainer used to hold the spark plug wires.
    "Drive it like you stole it"
    • Jack O.
      • July 31, 1996
      • 527
      Hi Floyd,
      Thanks for the input and help. I'm familiar with that AIM page and that's how I have my wires configured now. Going back and reviewing the TJM again, it mentions the clip came along with the second design valve covers but doesn't actually say the clip is for a plug wire so perhaps it's not. I can't find where it says what it's used for and there are 4 pictures showing it but not one of them have anything being retained by the clip. I originally had my temp sending wire routed through it as that seemed like a good use for it.
      Jack
      Jack Ottofaro
      • Jack O.
        • July 31, 1996
        • 527
        I should apologize for the noise. I just noticed that I'd asked this question twice before. I should've searched better before asking again.
        Jack Ottofaro
        • Gary B.
          • July 31, 1979
          • 926
          Can you post a picture of that clip? Please
          Gary B
          • Jack O.
            • July 31, 1996
            • 527
            Here you go Gary. Second one is what I have been referring to from the Technical Info and Judging Guide - something I believe you are a "little" familiar with .
            Jack Ottofaro
            • Gary B.
              • July 31, 1979
              • 926
              Thank you. I remember that manual well. Still chases me in my sleep..
              That clip is spot welded to the cover, with a vinyl ? coating on the hook.
              My 1968 April 1st built car does not have that hook. Let me look at some other cars... do some snooping.
              I think that pictures was from a 69 with 6,000 miles. After Greenville, I'll sneak in and look at it again.
              As I remember, it's unused on Corvettes. I think, it was used for the temperature sending unit on passenger cars maybe?
              Gary B.
              • Jack O.
                • July 31, 1996
                • 527
                Thanks for checking Gary. That it may have been only used on passenger cars never occurred to me but that makes sense.
                Jack Ottofaro
                • Chris H.
                  • April 1, 2000
                  • 837
                  From my December’68 car.
                  • Jack O.
                    • July 31, 1996
                    • 527
                    That's the one Chris. I see it's currently unused on your car. Do you know to the best of your knowledge if it ever retained anything?
                    Jack Ottofaro
                    • Chris H.
                      • April 1, 2000
                      • 837
                      Hi Jack, definitely not a plug wire and there’s nothing else in the vicinity. Closest thing is the temp sender wire and that about 6 inches away.
