seat separator compartment door, 1962 - NCRS Discussion Boards
  • Carl R.
    • October 31, 2018
    • 64
    I need some help on taking the lock cylinder out of the seat separator door on my "62". How do you get the lock cylinder out. Question #2 - how do you take the short chrome molding off the top section that is above the door. I am not seeing any obvious way that these things would come apart.
  • Leo G.
    • August 31, 1987
    • 116
    Re: seat separator compartment door, 1962
    Carl look in the sticky above restoration documents for the following by Richard Mozzetta. https://www.forums.ncrs.org/attachme...7&d=1499166257 It has a great explanation for this subject. Many subjects for that matter. I cannot help with the removal of the trim although I know it has been discussed on this forum.
    Good luck
    Drive safe
    Leo
    • Gary B.
      • February 1, 1997
      • 7053
      Carl,
      Once the push button is removed, I use a fabricated tool like this one with a Delrin octagon nose to remove the chrome bezel without damaging it. But you can also wrap a chisel or large screw driver in cloth, leather or rubber sheet.
      Gary
      • David Z.
        • April 1, 2002
        • 182
        Carl
        The attached PDF conatins good info on the subject.
        Dave Z
        Dave Zuberer
        • Carl R.
          • October 31, 2018
          • 64
          Thanks for the help guys, I have printed out the information that you sent and give this a try tomorrow. this is just the right information that I was looking for. Thanks again.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11341
            Carl,
            The 2 upper and 2 lower trims are held on with special clips and are snapped over the clips to attach. Use a plastic trim removal tool on the outer edges of the trim to remove them.
            Rich
            PS they look like this....
            • Carl R.
              • October 31, 2018
              • 64
              Thanks Richard for the picture of the clips. I saw these on the lower molding after I took the nuts off of the screws that was holding them on. The thing is when I went to remove the molding it was stuck in place, so I had to give it a little tap to break it loose, and when I did that the clips fell out. So I did not get a chance to see how they were attached to the inside of the molding. I will look at that tomorrow. I did get the lock out today. The hardest part about that project was getting the lock ring loose. You would think that GM would have made that hex shape a standard size to fit what most people would have on hand in there shops. Thanks for the help.
