56-62 with hardtop only - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8382
    did the st louis folks glue the cloth protector on the gas tank cover of hardtop only 56-62's? thanks, mike
  • Gary C.
    Administrator
    • October 1, 1982
    • 17659
    Re: 56-62 with hardtop only
    Mike,
    The '57 hardtop only car I once owned, did not have the softtop protector glued to the gas tank cover.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Patrick S.
      • January 1, 1988
      • 209
      I have owned two hardtop only Corvettes, a 57 and a 62. Both fairly original and both had the protector material glue to the gas tank cover.
      • Joseph L.
        • July 26, 2012
        • 162
        The AIM Section C, Sheet 1 shows the protector 3729460 as a standard part. RPO 419 (Hard Top) Sheet 3 (Less Folding Top) does not identify the protector being eliminated.
        Joe
        • Michael I.
          NCRS President - Director Region IX
          • February 1, 1999
          • 155
          Gary & Mike,
          I have a related question. I am pulling out the fuel tank on my `57 to clean it before putting any fresh fuel in. In any case when I pulled up the soft top protecter material to get access to the screws holding the tank cover on I discovered two holes cut through the fiberglass. They are very neatly done and provide access to the top nuts on the rear shocks. Seems like they ought to have some kind of rubber plug in them, but none are present. IS this something a prior owner did to make replacing shocks easier or is it factory? If factory, should those holes have some kind of plug in them?
          Thank you,
          Mike
          • Gary C.
            Administrator
            • October 1, 1982
            • 17659
            Mike,
            Those are factory holes. Material similar to tar paper covered those holes IIRC.
            57 Rear Shock Mount Hole Cover
            Gary
            NCRS Texas Chapter
            • Michael I.
              • February 1, 1999
              • 155
              Thank you Gary,
              That seems like a very inelegant solution. I assume the tar paper was glued down to actually seal those holes?
              Mike
              • David H.
                • June 30, 2001
                • 1526
                Originally posted by Michael Ingham (31749)
                .. I assume the tar paper was glued down to actually seal those holes?...
                Mike
                What? Waste glue on a 57?
                Dave
                Hope all is going well on your project. I'll ask Roy about this Wednesday.
                • Joseph L.
                  • July 26, 2012
                  • 162
                  Hi Mike
                  AIM Section J, Sheet 3
                  Shock Absorber Access Hole
                  SEAL 3740260
                  and sealing compound
                  Joe
                  • Joseph L.
                    • July 26, 2012
                    • 162
                    Screen shots do not work!
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11323
                      Thank you Gary,
                      Mike
                      Mike, Glue or weatherstrip adhesive should work fine. See AIM Sec J Sheet 3. View A.
