Distributor Shield - '66 L72 - NCRS Discussion Boards
  • Paul O.
    Infrequent User
    • April 20, 2022
    • 26
    My '66 L72 was built without radio (blank center console). When I bought the car both mounting brackets were there but no distributor shield. My understanding main purpose of the shield was to reduce engine interference to radio. Is it possible a distributor shield was never installed at the factory?
  • Bill M.
    • 1329
    Re: Distributor Shield - '66 L72
    Paul i believe the brackets also supported the spark plug wires. There should be a slot for a 4 hole grommet in the bracket.
    • Paul O.
      Infrequent User
      • April 20, 2022
      • 26
      Not sure if you can tell from photo, but there is a slot on top that held plug wires but no cover. Wondering if cover wasn't installed when no radio(?) thanks
      • Bill M.
        • 1329
        With no radio you would have no ignition shieding no grounding of your plug wires or any of the other 6 0r 7 ground strap wires throughout the car. Engine,exhaust antenna ect.
        • Paul O.
          Infrequent User
          • April 20, 2022
          • 26
          makes sense... thanks for confirming.
