How to convert power to manual brakes on a C3 - NCRS Discussion Boards
  • Bill S.
    Infrequent User
    • September 30, 1993
    • 12
    On my C3 I would like to convert my power brakes to manual brakes. The opening on the firewall is larger for power brakes than a manual brake system because of the brake booster. If I convert to a manual brake system I need a plate to fasten to the firewall which would enable the master cylinder of the manual brakes to be mounted to. Does anyone know who manufactures this plate? Also, is there a kit on the market which would provide the plate and whatever other components necessary to have a complete manual brake system?
  • David H.
    • June 30, 2001
    • 1569
    Re: How to convert power to manual brakes on a C3
    Originally posted by Bill Sagatys (23384)
    On my C3 I would like to convert my power brakes to manual brakes. ...
    Bill
    Curiosity. Gotta ask. How come? All had power brakes starting 1976.
    Dave
      • 11698
      Originally posted by David Houlihan (36425)
      Bill
      Dave
      Same thought here.
      I have a 71 without and 72 with.
      I wouldn't add power because it's a PITA to do that, but I sure wouldn't remove it!
      • Scott P.
        • April 30, 1992
        • 178
        Bill, you need to look in the AIM on the manual brakes page & PB page, you will find the firewall fiberglass piece is a different one and the metal mounting bkt behind the firewall fiberglass is different for manual and PB. Both can be changed out and should be for a good working brake system. The inside metal is the real important part because it moves the brake pedal leverage point to where it should be. A Corvette salvage yard would be a good place to find the parts. Scott
        • Bill B.
          • August 1, 2016
          • 308
          Hi Bill,
          To give you an idea, see the pics below. I converted my manual brakes to power brakes on my 1970. The first pic depicts the original manual brake firewall, with my preliminary markings in red of new hole positions required to mount the booster. (turns out, they were wrong as I tried centering the booster with the existing master cylinder center hole) The second pic is the firewall shown from the inside the cockpit looking forward. The third pic is the modification I had to make to the mounting bracket that Scott mentioned. The last pic is the completed mod to the firewall.
          (from the preview, looks like the pics may have gotten rotated 90 deg when I attached)
          Hope these help you understand the mods required. (I am also of the camp to keep the power brakes installed, but as an owner, I do understand it is your car and you can do what you like with it)
          Keep in mind that the metal clutch/brake bracket that came with a factory Power Brake installation is going to be different and require the opposite of the mods I performed. (the bottom holes will need to have welded nuts added and the top square cut-outs added) May be easier to obtain a used bracket as Scott suggested.
          Bill Bertelli
          Northeast and Carolinas Chapters Member
          '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
          • Dan B.
            • July 13, 2011
            • 545
            Same thought here.
            Well said. I had a 70 with manual brakes and never once gave a thought to adding power. That being said, it would not be hard to glass the larger opening over and reconfigure if you really want to and fabricate a plate as needed.
            This is the first time I've heard this type of request, and as asked would be interested to know what made you think of this.
            • Bill S.
              Infrequent User
              • 12
              Scott,
              Thanks for the reply.
              Bill
              • Bill S.
                Infrequent User
                • 12
                Bill,
                Thanks for the pictures and reply.
                Bill
