I have a 67 corvette and doing the rebuild on an oil cannister anyone know the order. I have copper washer on outside. Inside spring first then washer, rubber grommet, and cone. The lock ring or retainer clip does it go flat part up or down?
					Oil Cannister Assembly order
Re: Oil Cannister Assembly order
Shane,
Before you assemble the filter, could you please measure the washer and rubber grommet for me? Since no one sells the rebuild kit anymore I am going to make do with what I can make. I just need their dimensions.
DonThe light at the end of the tunnel has been turned off.- Top
Good work Shane!
What is the outside diameter of the rubber washer(grommet)?
The only outside of the canister is the copper crush washer - right? Or did you mean the metal washer above the spring , below the rubber grommet? Is this to seal off the bottom of the cone?
Shane, any automotive store carrys the cooper and rubber washer just have to match them up, 99% of time lower crush cooper washer leaks the rest of items you can reuse- Top
Which automotive store?
I tried autozone, O’Reilly’s, napa
