cleaning knock off wheels - NCRS Discussion Boards
  • Mel S.
    • August 31, 1992
    • 264
    I just put on new after market knock offs on my 66. They look great on the car because they are new. What is the best way to keep them looking this way.
    Mel
  • James W.
    • December 1, 1990
    • 2655
    Re: cleaning knock off wheels
    Mel,
    DO NOT use Wesley's brand cleaner on your tires or wheels. I have always had good luck with Simple Green mixed 50/50 or the Meguires G 14324 Hot Rims Aluminum Wheel Cleaner. Use a good quality wheel brush that does not have any metal that holds the brush bristles. You'll want one that is slim and will fit between the fins. For polish, I use Semachrome or Wenol metal polish for the outer rim.
    James
    • Mark F.
      • July 31, 1998
      • 1524
      Originally posted by James West (18379)
      Mel...For polish, I use Semachrome or Wenol metal polish for the outer rim. James
      Mel and James,
      I use Wenol as well.
      Amazing what that stuff pulls off and how nice they look afterwards...
      thx,
      Mark
      • Mel S.
        • August 31, 1992
        • 264
        Thanks for the information. Next trip to purchase items
        Mel
        • James W.
          • December 1, 1990
          • 2655
          Mel,
          Enjoy your new K O's.
          Be sure to install and tighten them correctly. After I tighten mine, I use a white paint marker and draw a line across the center cone and the knock-off spinner so that I can monitor the spinner for any movement. I usually check them after 50 miles and again at 100 miles to be sure they are staying tight. Then usually every tank of gas.
          James
          Mel
          • Mel S.
            • August 31, 1992
            • 264
            That was going to be my next item. Checking the lugs frequently!
            Mel
            • Alan D.
              • January 1, 2005
              • 2038
              Mel,
              Here's another though - have them cleared! Yes you will loose some points.
              In the past I've lost in originality -2, -12, -8, 0 They are worth 30 points so you could loose up to 6 for finish.
              Just depends upon how correct your car is, I've always been Top Flight.
              Cleaning can be very time consuming on these.
