69 Ball Joint Questions - Again - NCRS Discussion Boards
  • Michael C.
    • January 9, 2013
    • 332
    I posted the questions below (and others) over a month ago. The only reply didn't address the questions. I've done more search on this forum, but haven't found definitive answers (that I can understand)...so here I go again.
    This information comes from the Specifications section in the Chassis Service Manual.
    Spherical Joint - Stud to Control Arm Nuts (Service) - 20 ft lb. Is this for the bolts/nuts that replace the rivets holding the ball joints to the control arms? Sure seems low.
    Next under Bolt Torques - Lower Forging Nut - 40 ft lb. What is this? Can't find it in the AIM.
    Mike
    • 43290
    Re: 69 Ball Joint Questions - Again
    Mike
    Mike------
    As I may have mentioned previously, the bolts used in SERVICE to secure the ball joints, upper and lower, to the control arms are 5/16-24. I can't recall if they are GM 280M or 300-M but 20 lb/ft is the appropriate torque for such bolts whether used to fasten the ball joints or any other use.
    The "lower forging nut" is the nut at the center on the UPPER side of the lower ball joint (below the grease fitting). That nut is torqued to 40 lb/ft. PRODUCTION specification was 35-45 lb/ft. Most SERVICE torque specs are set in the middle of the PRODUCTION range.
    • Michael C.
      • January 9, 2013
      • 332
      Thanks Joe for the clarifications.
      • Ron G.
        • December 1, 1984
        • 866
        Michael, send me your email address and I will send you a chassis torque sheet that GM recommends. My email address is: RgodutiLT1@yahoo.com.
        - Ron
        "SOLID LIFTERS MATTER"
        • Michael C.
          • January 9, 2013
          • 332
          Ron, I've sent my email address to your email.
          Thanks for the offer, I look forward to adding this to my library.
          Mike
