1963 Power Windows - NCRS Discussion Boards
1963 Power Windows
  • Gerald C.
    • June 30, 1987
    • 1296
    1963 Power Windows
    Can someone with a 1963 and power windows take a picture(s) of their circuit breaker(s) that are on the left side pillar just above and in front of the vent? I want to see if the pw harness, the cigarette lighter and the up/down headlight switch are all on the same terminal? The other terminal should hold the power window wire coming out of the fuse block. Just looking for the correct configuration.
  • Bruce G.
    • May 31, 2003
    • 77
    Re: 1963 Power Windows
    Hi Gerald - Let me know if these pics are what you need..............if not I can provide more. Bruce
    • Gerald C.
      • June 30, 1987
      • 1296
      Bruce
      Thanks for these. However, I'm looking for pictures of the circuit breakers and how the wires are attached. Specifically, the pw wire to the fuse block and the pw harness, the headlight up/down switch along with the cigarette lighter
      Jerry
      • Edward G.
        • September 30, 1978
        • 46
        I show only one circuit breaker,hope this helps
        • Leif A.
          • August 31, 1997
          • 3638
          The one you're showing is for the power windows, there is a second breaker for the headlight motors located above the "Z" bar. See picture below borrowed from Buns. Top square hole is for the headlight motors breaker and the lower square hole is for the power window breaker.
          Leif
          • Paul W.
            Infrequent User
            • October 28, 2021
            • 4
            Having wired my power windows as pictured in Edward's post #4, should my windows operate without the use of the key?
            • Harry S.
              • July 31, 2002
              • 5328
              Yes, no key needed. It's a safety issue. In an emergency you need to get the window open.
              • Paul W.
                Infrequent User
                • October 28, 2021
                • 4
                Thanks for your attention to my Power Window inquiry! Why then was phrase "Electrically operated windows will not function with the ignition key in the off position" added to TIM&JG 7th edition, Operations #29, when it was not mentioned in 6th edition?
                • Harry S.
                  • July 31, 2002
                  • 5328
                  Paul, there are a number of items in the new JG that are being questioned. As I understand the new 63/64 Team Leader, Joe Scafidi, is looking into these items. Might I suggest you send Joe an email. His contact information can be found above under the Contacts Link.
                  • Joseph S.
                    National Judging Chairman
                    • March 1, 1985
                    • 878
                    Paul, No need for an Email about this. We have already corrected the issue. 63 & 64 Power windows should work off Battery Power. The key position has no bearing on its function.
                    Regards, Joe
