1965 Frame VIN Mis-stamp - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2655
    I found and recorded my unrestored '65 frame VIN stamp 5S122095. I found something interesting in that the factory mis-stamped the frame number. The first stamp was 5S122094 but they re-stamped the last number making it a 5. No grind out, just stamped slightly below the last number.
  • David H.
    • June 30, 2001
    • 1530
    Re: 1965 Frame VIN Mis-stamp
    James
    A few photos from CF.
    Dave
    AEF84B5C-2655-4916-9E2B-C7540CD52D91.jpeg6E81DB96-A29A-43A1-8785-D1A6EC4CD1C7.jpegMill Frame Stamp For Label copy 2.jpg
    • Michael B.
      • February 1, 1985
      • 76
      • Mike M.
        • May 31, 1974
        • 8385
        the frame stamping tool causes a slight denting of the underside of the frame, so a repo frame that has been stamped in amateur fashion will usually lack the dent . mike
        • James W.
          • December 1, 1990
          • 2655
          The car has been in the family since 1974 and has never been apart until I began the rear suspension rebuild last winter. This is not a repro frame.
          James
          • Gary B.
            • February 1, 1997
            • 7023
            • Mike M.
              • May 31, 1974
              • 8385
              jim: didnt mean to imply the frame a repo. simply noted the presence of denting so chassis judges would be aware. mike
              • James W.
                • December 1, 1990
                • 2655
                Mike,
                I didn't think you were, just stating it's history. You also taught me something, I was unaware of the indentation at the frame VIN stamp at the door location vs. no indentation at the rear of the frame.
                James
                • Gary B.
                  • February 1, 1997
                  • 7023
                  • David H.
                    • June 30, 2001
                    • 1530
                    Originally posted by James West (18379)
                    ... indentation at the frame VIN stamp at the door location vs. no indentation at the rear of the frame. ...
                    James
                    BOTH locations have frame indentations from that stamping machine.
                    Dave
                    • Gary B.
                      • February 1, 1997
                      • 7023
                      • Jimmy G.
                        • November 1, 1979
                        • 976
                        It happened a lot more times than you think production line workers at $ 5 an hour mistakes happened quite often
                        • Joe R.
                          • July 31, 1976
                          • 4550
                          $5.00 an hour! You must be kidding! Ask M. Hanson! He was there on the line and took those pictures!
                          JR
