C2 Rear Strut Bushings Installation Question - NCRS Discussion Boards
  • Larry E.
    • 1698
    Will be installing the #3775762 GM bushings on my original strut rods(1 1/4) diameter. Could not
    find an answer to my question upon researching this board. Here Goes>
    Should the bushings be pressed in "Dry" or some Oil be applied to the the strut rod? Or perhaps some
    modern day lube/penetrant like "CRS Freeze-Off" which makes the metal contract temporary before
    returning back to normal be OK? Would this make the job easier? Comments Please>Thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Bill M.
    • 1328
    Re: C2 Rear Strut Bushings Installation Question
    Larry i have always pressed the bushings in after applying a little wheel bearing grease around the bushing and inside the rod. So there is no dry areas. Never had a problem.
    • Gary R.
      • April 1, 1989
      • 1806
      I machined a press tool and never had to lube or freeze them. Maybe a little WD40 but the tool applies pressure to the bushing sleeve to press in.
      • Bill M.
        • 1328
        For years I used a large socket and a C clamp to instal bushings and U J s. Eventually I bought a press. A little lube and the slide right in
