C 4 Sport Seat (1993) Seat Lumbar Bladder(s) - NCRS Discussion Boards
    • October 17, 2013
    • 69
    Looking for suggestions on repairing the lumbar seat bladders in my 1993 for PV. The replacement bladders have been discontinued and I've been unable to locate any as of yet. If one of the ZR1 parts hoarders has a set please send me a PM with price. I was also thinking of inserting three "air shims" into the existing plastic bladders and feeding them with the existing pump. My pumps and air releases are working perfectly. Has anyone tried this, or have a better idea to repair the lumbar chambers?
  • David H.
    • June 30, 2001
    • 1526
    Re: C 4 Sport Seat (1993) Seat Lumbar Bladder(s)
    John
    Send C4 National Team Leader, Tom Barr, an email. Expect he can direct you to someone or how to repair.
    Dave
    Tom is under CONTACTS drop down at page top.
    • Mark E.
      • April 1, 1993
      • 4542
      What's wrong with the bladder? If ruptured or torn, can you patch it?
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Brad Hillhouse (37766)
        Mark - The rubber seat bladder turns brittle and breaks into multiple pieces when they go bad and no longer hold air. In this photo you are looking at yellow plastic material which is the bladder that has become brittle and broken inside the seat foam.
          • 43221
          [ATTACH=CONFIG]111253[/ATTACH]
          Brad------
          With that kind of deterioration I highly doubt that repair will be possible. But, you never know.
          If it helps, the part number you are looking for was GM #14079496. This part number is applicable to a wide year model range for Corvettes----1984 to 1993. So, there's going to be a lot of other C4 owners with sports seats that either have had or will have the same problem you have.
          A curious note: way back in 1991 when I ordered my 1992 I thought about ordering sports seats. However, I figured that the "inflatable components" of the seats might be troublesome at some point. So, I opted not to order them. Of course, if I had ordered them I likely would have obtained spare bladders long before I needed them and, thus, would have been "covered" if and when failure occurred. But, I didn't order the AQ9 seats so I never obtained any spare bladders.
            • October 17, 2013
            • 69
            Dave,
            I have spoken with Tom. I used my last set on a 90 ZR1 and haven"t found another set.
              • October 17, 2013
              • 69
              Mark they aren't as bad as the images below. I'm disassembling everything today. Whoever was making the replacements seems to have discontinued the reproduction. That's why I wondering if I could insert an air shim, or like a blood pressure cuff into the seat to serve as the three chambered bladders.
                John do you need one side or both?
                Brad
                  • October 17, 2013
                  • 69
                  Both, the each have at least one leaker.
                  • Keith K.
                    • January 23, 2008
                    • 510
                    It is the rubber membrane that deteriorates. I took the assembly apart and cut a new rubber piece from a rubber dish-washing glove, reassembled, and it worked. 93 ZR1
