Fascinated by the use of Clutch Head screws on various parts of my 61 Corvette - extreme examples ... the grab-bar (eight of them seemingly for a higher torque application, headlight bucket attachment screws to the front fenders (seemingly light torque application).
CURIOUS
since Phillips head screw was a prevalent fastener throughout the C1's - why did GM select clutch Head screw type in certain areas and not in others - seems like it adds complexity to the assembly process?? Are they easier to use than Phillips in manufacture back in the early 60's? I don't recall clutch head screws on my 1966?
DEFINITION FOUND
"Standard Clutch", resembles a bow tie, with a small circular "knot" at the center. These were common in GM automobiles, trucks and buses of the 1940s and 1950s. Type G resembles a butterfly, and lacks the center "knot".[48] This type of screw head is commonly used in the manufacture of mobile homes and recreational vehicles.[49] The clutch head was designed to be driven with a flat-blade screwdriver as well as a clutch driver."
CURIOUS
DEFINITION FOUND
