On a 1966, How In The World Do I... - NCRS Discussion Boards
  • Don L.
    • August 31, 2005
    • 1005
    ...remove the special retaining nut that holds the windshield wiper switch to the dash? I see the two slots, located 180* apart and that means a special tool is needed. I looked on line but could not find a tool that slides over the switch's 1/2" diameter threaded stem. I find only 3/8" and 11/16".
    I'm working on this car and I'm growing desperate, as the regional meet is coming up fast and I need to replace the switch in order to get full points on washer/wiper. Does anyone know where I can get the needed tool?
    Any help is much appreciated.
    Don Lowe
    NCRS #44382
    Carolinas Chapter
  • Mark M.
    • October 21, 2008
    • 340
    Re: On a 1966, How In The World Do I...
    Don try Paragon for their # 12593. 1-800-882-4688. They ship fast. A number of vendors sell them. I got one a long time ago from Long Island. Good luck
    • Robert P.
      • October 19, 2019
      • 317
      Don, i have one you can borrow sent you a PM
      Bob Peckham
      • John F.
        • March 23, 2008
        • 2413
        Needle nose pliers do the trick. Just go slow!
        • Stephen L.
          • May 31, 1984
          • 3159
          Get a cheap deep well socket that fits over the threaded area. Then grind off either side on the end leaving a couple of tabs protruding 180 deg apart. It should look like the Paragon tool when done.
          • Bill M.
            • 1328
            i use 2 small pocket size screwdrivers 1 in each slot and just turn them. a drop of WD 40 will help
