Block casting date - NCRS Discussion Boards
Block casting date
  • Dave B.
    • February 26, 2021
    • 35
    Block casting date
    I have a 69 convertible that has been confirmed as starting life as a L-71 by a NCRS judge. The previous owner swears the block is the original how ever the block was cast 2 days after the car was assembled. Does anyone know of any scenario where this could be possible? I'm thinking not but who knows.
  • Mark F.
    • July 31, 1998
    • 1555
    Re: Block casting date
    Hi Dave,
    If all was TFP, it would not seem logical at all. 1st the Block is cast; machined; assembled; shipped to St. Louis, etc.
    if the casting date plate used to emboss the outer skin mold was incorrect for the day actually cast - then there would probably be other blocks out there with the same "anomaly" - until QA guys spotted the incorrect date. dunno how often (or even if) that happened?
    What are you using to determine the assembly date?
    • NCRS Shipping Report?
    • Body Build Date +1 or 2?
    How does the engine pad assembly stamp date compare to the block casting date? (how many days different?)
    Photos would be helpful for others who are more knowledgeable than I on this topic...
    thx,
    Mark
      • 43242
      Dave------
      There is one possibility I can think of: if there was a problem with the engine after completion of the car, the car would have been shunted off to the heavy repair unit at St. Louis. If they determined that the engine could not be repaired, they would have installed a new engine. This whole process might take several days. It's an unlikely scenario but it is possible.
      What are the stamp pad engine code and VIN derivative like? Photos of the stamp pad would be helpful.
      • Dave B.
        • February 26, 2021
        • 35
        Thanks for the help. I'm using the date on the trim tag inside the drivers door for the car assembly date. Unfortunately the block has been shaved so there are no numbers on the stamp pad. The pervious owner is the one who had the block shaved and he says the numbers did match the VIN number. This was all done about 30 years ago before these cars were big ticket items.
        • Roy S.
          Past National Judging Chairman
          • July 31, 1979
          • 1025
          Dave------
          If that happened the NCRS shipping data report would confirm the later build date because of heavy repair.
          • Edward M.
            • November 1, 1985
            • 1922
            Dave, can you provide specific data, and particularly photos of the block casting date, the engine front pad stamp, and the trim tag that shows the vehicle assembly date.
            What you are suggesting sounds highly unlikely, but it may be a simple as mis-reading the information on one of the items discussed here, or misinterpreting some of the data.
            Looking at the data is the best way to discern this.
            • Kenneth B.
              • August 31, 1984
              • 2091
              Since the block was decked there is No way to say what it is. It's all a mute point now.
                • 6948
                Dave, does your car have a build sheet on top of the fuel tank, you can verify what engine the car was born with.or documents from purchase.
                • Dave B.
                  • February 26, 2021
                  • 35
                  Nope, tank sticker is long gone.
