63 rear spring liner length - NCRS Discussion Boards
  • Todd L.
    • November 25, 2020
    • 298
    I am restoring the rear spring for my 63 and purchased the spring liners from Quanta. The liners between the 2nd, 3rd, & 3rd, 4th springs are 2" shorter than the spring. The others are the same length as the springs. Can anyone tell me if the others are supposed to be cut 2" shorter than the spring to match the first two liners?
    Thanks!
    Todd
  • Harry S.
    • July 31, 2002
    • 5344
    Re: 63 rear spring liner length
    Todd, I save the original lines from my 63 spring, I'll measure them for you. Please remember there is no liner between the top two leaves.
    • Harry S.
      • July 31, 2002
      • 5344
      I need to double check where there is no liner.
      Longest to shortest ----> 44.00, 39.00, 33.25, 29.00, 24.50, 20.00, 16.00, 11.00
      • Harry S.
        • July 31, 2002
        • 5344
        I can't get under the car. Here is my spring after I restored it. No liner between the top two.
        • Todd L.
          • November 25, 2020
          • 298
          Thanks for the info Harry. You have 8 measurements there, I believe there is only 7 liners, correct? If so, which one of those is not correct?
          • Todd L.
            • November 25, 2020
            • 298
            Harry,
            After you mentioning you had your old ones, I dug around and found mine as well. This may answer my question, but it appears the two short ones are not long enough, and the others are all ok. Would you agree? If so, it looks like I need to purchase more of these liners and cut them down for the short ones?
            Todd
            • Mark F.
              • July 31, 1998
              • 1591
              Originally posted by Todd Lawson (67502)
              Harry, After you mentioning you had your old ones, I dug around and found mine as well. This may answer my question, but it appears the two short ones are not long enough, and the others are all ok. Would you agree? If so, it looks like I need to purchase more of these liners and cut them down for the short ones? Todd
              Hi Todd,
              I'm not a '63 guy, but you are only showing 7 leaves in your image.
              If I counted right, Harry's image has 9 leaves.
              Was there a 7-leaf spring in '63? (I don't know), but that could be a point of confusion.
              I'm sure a '63 guy will weigh in and set the story straight
              thx,
              Mark
              • Harry S.
                • July 31, 2002
                • 5344
                In 63 you only had a 7 leaf spring on a Z06 as I recall. Let's start with what suspension we are dealing with?
                • Harry S.
                  • July 31, 2002
                  • 5344
                  Forget the 11 inch one. That is one from Quanta sent in error.
                  • Harry S.
                    • July 31, 2002
                    • 5344
                    I was thinking back to when I restored my 63 spring, almost 20 years ago. I had a difficult time trying to convince Quanta that the liners in a 63 spring were different than 64 - 67. They finally sent me a piece of uncut liner that I cut and trimmed to the length I needed.
                    • James W.
                      • December 1, 1990
                      • 2671
                      Todd,
                      If you find that you in fact do need extra liner material, I have a roll of liner material I bought from I think LIC or Quanta a few years back that you may have.
                      James
                      • Todd L.
                        • November 25, 2020
                        • 298
                        Sorry for the slow response, I've been out of town since Thursday evening. I will contact Quanta and see if they are willing to send me an uncut length that I can make work. If not, I would be happy to pay shipping for yours James. Thank you so much for offering it, that is very kind of you.
                        Todd
                        • Todd L.
                          • November 25, 2020
                          • 298
                          Thanks for the info Harry, I will reach out to Quanta to see what they have to say.
                          • James W.
                            • December 1, 1990
                            • 2671
                            Tell me how long of a piece you need and I'll send it to you. Will send you a PM/email to gwt your shipping address.
                            James
                            Todd
