1969 350 tach drive distributor needs rebuilding - NCRS Discussion Boards
  • Robert J.
    Infrequent User
    • January 15, 2021
    • 3
    Has anyone in the Portland Oregon area used or know of a quality machine shop that rebuilds old tach drive distributors?
    Thanks.
    Bob
  • Don H.
    Moderator
    • June 16, 2009
    • 2258
    Re: 1969 350 tach drive distributor needs rebuilding
    Bob
    this question should go in the Tech Discussion Board.
    Someone will have an answer for you
    Good luck,
    • Michael L.
      • December 15, 2006
      • 1390
      Thanks.
      Bob
      Bob,
      The Rebuilding of the old tachs has probably gone out of style with many of the machine shops. These tachs are of a unique enough nature that it pays to have a specialist in this area do this for you. You should be getting copies of Driveline with your membership and you can find someone in there who specailizes in doing this. That's definitley where I would advise you to start.
      Mike
      • Allen N.
        • January 1, 2003
        • 288
        Bob
        I would recommend Dave Fiedler. He restored the distributor on my 70 LS5. He is in the Driveline, and his website can be found at:
        T.I. Specialty is pleased to provide information pertaining to Corvette ignition systems. We are experts in our field and want to help you with your vehicle.
        Allen
          • 15670
          As long as the bushings are okay it's easy for a DIYer to rebuild it. The procedure is in your COM, but don't forget to install the gear with the dimple pointing to the rotor tip. The service literature doesn't mention this.
          Get a shim kit and shim up the end ply to 2-7 thou, and it's also a good opportunity to optiimize the spark advance map per my tuning seminar.
          Duike
          • Robert J.
            Infrequent User
            • January 15, 2021
            • 3
            Thanks for everyone's input. I called Dave and after talking with him for ~30 minutes decided to send mine to him for rebuilding. Hard to beat 40+ years of experience and expertise!
