65 soft top - NCRS Discussion Boards
65 soft top
+ More Options
Posts
  • Keith B.
    • September 15, 2014
    • 1588
    65 soft top
    Was the soft top put on the soft top frame at the assembly plant or was the whole assembly done when came in from the supplier? at a chapter meet today it was pointed out that the lace caps where not correct. looking at the original top the repro caps match. This car being a A O Smith body would they have used different hard wear?
  • Keith B.
    • 1588
    Re: 65 soft top
    anyone have a answer?
    • James W.
      • December 1, 1990
      • 2668
      Re: 65 soft top
      Keith,
      The hardware should be the same, regardless of whether the car body was built in St. Louis or at AO Smith. The cap in the picture should be correct. They look like the one's on my car. Somewhere I have pictures of an original soft top that show all the correct hardware. There used to be two different types of caps, one had a flanged edges that looked like a spear.
      James
      • Keith B.
        • 1588
        Re: 65 soft top
        When was the cap with a flange first used?
        • James W.
          • December 1, 1990
          • 2668
          Re: 65 soft top
          Keith,
          Keith,
          Here is information out of the 1963/1964 TIMJG and the 1965 TIMJG. The 63/64 manual references either the non-flanged caps or flanged caps. The '65 manual also says that the soft top wire-on tips may have either the non-flanged or flanged edge.
          James
