Re a 61 - I need to remove the 4 clutch head screws holding the passenger grab bar - can you please tell me what size clutch bit is required to remove those large clutch head screws! Thank you!
C1 Grab Bar Clutch Head Scew - Size?
Re: C1 Grab Bar Clutch Head Screw - Size?
Peter I'm away and can't check my tool box but in a pinch try using a good heavy duty #2 flat blade screwdriver to remove them.
Even better if its a Snap-On with the base of the shaft you can put a wrench on for extra torque.
Rich- Top
Pete
You will have a use for a variety of sizes on your 1961. Why not seize the opportunity to expand your tool collection. It will stand you in good stead for the future.
https://www.amazon.com/CTA-Tools-875.../dp/B007RKOBOM
I am sure these are not as good as Snap-on, almost nothing is, but in a pinch these will work more than once.Terry- Top
